Wires? AVIC-Z1
By rock crawler · Nov 09, 2006in Vehicle Specific Wiring💬 4 posts👁️ 1,597 views
Posted Nov 09, 2006 · 15:54 UTC#1
Please Help - need VSS, Reverse, and ILL wires for 2006 Dodge 2500 Mega Cab w/ diesel. My AVIC-Z1 was produced in June, how do I bypass the gyro? I would like for all the functions to work while I am driving.
Posted Nov 09, 2006 · 16:03 UTC#2
Please don't be lazy. Just read and search the forum for a few minutes. The link to the bypass information has been discussed HUNDREDS of times already. I just timed myself and it took me 12 seconds to find the information.
Posted Nov 09, 2006 · 16:53 UTC#3
Posted Nov 10, 2006 · 00:50 UTC#4
Consider getting a canbus adaptor. It WILL be a lot easier to use since it will give you vss, illumination, and accessory power right there at the radio. If you really want to go the hard way, here's your wiring info.
Accessory
You need this because your truck doesn't have one behind the radio. You have 2 options to run a wire from the cigarette plug to the radio or run a line from the ignition
Ignition pink/white + ignition harness
illumination
You can use either of these wires
Parking Lights+ white/yel (L), white/gray ® + harness at top of driver fender
Reverse Light white/lt. green + harness at top of driver fender
Speed Sense dk. blue/orange (SRT-10 only) PCM, black/gray plug, pin 27
Notes: The PCM is on the passenger side firewall. The black/gray plug is the second plug down from the top.
There ya go
merry xmas
