Can someone point me to instructions on how to make install modifications. I have a 700BT with 3.0. All of the mods tell you to modify files but they do not tell you where these files are located.
Posted Aug 11, 2009 · 17:51 UTC#1
OK, I will spend another few hours looking. Thanks for your help.
In general, all the mods are done in the data.zip file.
Do you simply unzip it do the mods and then rezip it? So I do not get the wrong one, where is it located?
BooBoo
I am really a novice but can offer the following advice which may help.Mods which require the data.zip file are usually copied as they are(ie still zipped)into the APL2/IGO folder which can be found in your flash drive.Please read all the threads on modding before trying anything and back up your entire my flash drive first.Then if everything goes t*ts up you can at least get your unit working again.Good luck.
Got it. Thanks
