D3 install in a mk5 VW.. power issue
By Asmo404 · Aug 11, 2009in Problems/Troubleshooting💬 5 posts👁️ 1,683 views
Posted Aug 11, 2009 · 22:05 UTC#1
Hey all,
Ok, so I've done the install myself using a wiring harness I got from futureshop (and it works, I might add)
My issue here is that because the mk5(jetta/gti/rabbit/golf) radios have constant power... my avic unit ends up having constant power.
Should I rewire the acc/batt wires, or is there a work-around for this problem?
Anyone?
Adam
Posted Dec 30, 2012 · 05:22 UTC#2
IM having this same issue anyone have any luckw ith this?!?
Posted Dec 31, 2012 · 02:18 UTC#3
I am having a similar issue. Any feedback?
Posted Jan 02, 2013 · 19:41 UTC#4
ANYONE ther ehas to be someone on here that installed an AVIC in a jetta before!!
Posted May 05, 2013 · 14:40 UTC#5
you guys have to run a acc source from your fusebox or you can tap into the igniton source. I installed this unit in a 2010 dodge and i had to run a wire from my ignition to the back of the deck so that it will turn on and off with the key.
