Bypass problem
By ronjhoser · Jul 20, 2009in Hacks/Mods💬 2 posts👁️ 995 views
Posted Jul 20, 2009 · 21:59 UTC#1
SO,
After doing the 2 wire bypass on a Z2 of 2007 vintage, the nav gets a little bit crazy and it appears that you are driving sideways. After removing the added wire in the second harness, everything goes back to normal... any suggestions on this one? I should also mention that this unit has had a software update after experiencing lockup problems.
Posted Aug 12, 2009 · 01:06 UTC#2
Verify that you moved the wire to the correct location in RCA harness 2. Try resetting the 3D calibration settings.
