Differences Between AVIC-X910BT and F90BT?
By TheColorCute · Aug 12, 2009in General💬 4 posts👁️ 3,130 views
Posted Aug 12, 2009 · 16:04 UTC#1
I"m a newb to the forum so please forgive my lack of AVIC knowledge haha :)
What are the differences between the X910Bt and the F90BT? Is the X-Series worth the extra money? Is the X-Series firmware faster? In what ways, if any, is the X-Series worth the extra money over the F-Series? Which one should I get (I don't really mind paying an extra hundred dollars or so for the X90BT), or, which one is better to get?
Thanks! :)
Posted Aug 14, 2009 · 19:08 UTC#2
The X series and the F series are essentially the same thing. The F-series made such a bad name for itself that Pioneer released the next generation F-series as the X-series instead to try to leave the tainted name behind.
From my own experience with the F-series (I work for an electroncis shop), I would recommend getting the X-series because there is a known hardware issue with the F. You are able to upgrade your F's software so that it has the same software as an X, however you will still have the old hardware. Other than that, they are pretty much identical.
Posted Aug 18, 2009 · 10:13 UTC#3
Does anybody know the exact hardware differences ?
Has the x-series more flash disk size or similar?
Christian
Posted Sep 12, 2009 · 01:24 UTC#4
I know that the f90bt offers a higher voltage output on the preouts, so if your using external amps you will get a much cleaner powerful sound. Correct me if I'm wrong.
Rock
