Selecting a destination by icon on map
By propman07 · Aug 13, 2009in General💬 6 posts👁️ 956 views
Posted Aug 13, 2009 · 05:36 UTC#1
If I remember correctly, on the Z1, Z2, and Z3 AVIC models, you could touch a POI's icon on the map, and you would have the option to make this your destination. I can't seem to get the same functionality out of the Z110BT.
Am I mistaken, or is this feature missing?
Posted Aug 13, 2009 · 08:09 UTC#2
Nope, its there. Make POI icons visible on the map. Touch the icon then touch the shortcuts button on the right. Hit the destination flag.
Posted Aug 14, 2009 · 03:47 UTC#3
Okay, I tried that. POIs visible on map. When I touch the icon on the map, nothing happens. If I scroll the icon on the map so that it is in the center (under the red circle), then I can press the shortcut button, and I get the destination flag. For some reason, the POIs on the map don't do anything when I select them.
Is there another setting that I'm missing? My Z110BT is using ver 1.0 if that helps at all.
Thanks.
Posted Aug 14, 2009 · 04:57 UTC#4
Nope, thats how it works. If you need to see info for the POI once you place the red circle on it, there is a little text file icon at the bottom right you can click.
Posted Aug 14, 2009 · 14:18 UTC#5
Ah...I see. Like I mentioned, I thought that I remembered on the Z3 that you could touch an icon directly. This method will work, it will just take a little getting used to.
Thanks for the replies.
Posted Aug 14, 2009 · 16:52 UTC#6
Yea there is no placing of the cursor on the map by touching it. You just have to drag the cursor to the position you want.
