How to? Update F-Series to X-Series
By PowerOutage · Aug 16, 2009in Hacks/Mods💬 8 posts👁️ 1,645 views
Posted Aug 16, 2009 · 17:42 UTC#1
I've bought the 3.0 Firmware and am awaiting the generator site to come back online https://www.pioneernavigationupdate.com ... ionupdate/
In the meantime I have a question... when I finish updating is it possible to load up the x710bt software to my f700bt AVIC?
I would really appreciate a step by step guide on the process as I'm sure it can't be as simple as a data.zip drop.
Posted Aug 16, 2009 · 18:46 UTC#2
there is a whole how to without paying for it... Go down to the 3.0 HOW TO
Posted Aug 16, 2009 · 19:59 UTC#3
You mean "stealing it without respect to copyright holders"
Say what you mean, and if you're ok with that, fine, but don't sugar coat what you're doing.
Posted Aug 16, 2009 · 20:07 UTC#4
Well my question is, now that I've payed for it and soon will be able to finish the update what would be the next step if I wanted the features the x-series have... like the button sound disable.
Posted Aug 16, 2009 · 22:06 UTC#5
the 3.0 update effectively turns the f into an x. All that is different is some hardware. In fact the f series actually includes a newer version of wince then what was provided to the x series unit, 3.02 is f and 3.01 is x.
Posted Aug 16, 2009 · 23:13 UTC#6
ok so if i were to turn on a x710bt it would be exactly the same as my f700bt w/ 3.0
Posted Aug 17, 2009 · 00:03 UTC#7
I believe that is mostly true, but if I'm not mistaking, the x has a hardware graphics accelerator to allow some drag/drop action that isn't in the F.
But in most aspect - it would function almost identical...
EDIT: see post below. The statements above ARE NOT CORRECT.
Posted Aug 17, 2009 · 00:38 UTC#8
No that is not correct, you are thinking of the new z series. Considering we were running the x series drive image ona f series with no issues, that tells you the hardware is nearly identical, if not actually so. The main difference is the face and button layout.
