Will a Z110Bt fit an '03 Subaru Outback? I want to make sure before I go and spend $1600+ on a HU (plus the MSN Direct tuner and the iPod Cables).
Thanks! ![]()
Thanks! ![]()
do you have a double din in there right now?
If its a single din you are likely out of like
Yeah, it's a triple din actually. So, it will fit. Both Bestbuy.com and Crutchfield say it will. So, it should be fine.
Thanks! ![]()
ah ok then you should be good
