Development of Mods
By UllSang · Aug 19, 2009in Hacks/Mods💬 6 posts👁️ 1,297 views
Posted Aug 19, 2009 · 00:49 UTC#1
I remember people were able to get a VM of their unit so they could test out modifications their instead of having to do so out in their car every time.
Does anyone know where I can get current instructions/tips for doing so using 3.02?
I have Windows Embedded CE 6.0, will that work? Or what do I need?
The main thing I would like to do is modify the map screen and make changes there builidng off of "Diaftia's Keeper" mods.
Any help would be greatly appreciated.
Posted Aug 19, 2009 · 00:56 UTC#2
All you really need is the Microsoft Device Emulator, running it at 800x480 video and attach a copy of APL2 folder as its flash disk. Make sure that you leave one card only in content\map folder. You should be able to start the EZRider.
Posted Aug 19, 2009 · 02:27 UTC#3
So your saying I need: http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=a6f6adaf-12e3-4b2f-a394-356e2c2fb114 (Microsoft Device Emulator 3.0) And a copy of the flash disk contents. With that I turn it on and It boots and works as expected. Two questions:
1.What do you mean by having one card in content/map folder.
2. Starting EZrider is what runs the whole avic frontend and launches all the apps correct?
Posted Aug 19, 2009 · 03:59 UTC#4
I've been using Device Emulator 1.0 and that worked. I think 3.0 should work just as well.
1. Sorry, I meant one map in there.
2. No, EZRider is the navigation executable. Main menu is MainMenu.exe
Posted Aug 22, 2009 · 22:18 UTC#5
Two more questions if someone can answer:
1. I was wondering where I can get the WinCE Image from 3.0? The one from http://avic411.com/forum
/viewtopic.php?f=34&t=26673 Is a WinCE 5.0.
2. Everyone keeps talking about keeping one map in there. are they referring to: "../My Flash Disk\APL2\iGo\CONTENT\MAP" and removing all the maps but one, and if so which one should I use?
Posted Aug 23, 2009 · 00:47 UTC#6
In the 3.0 and emulation thread there's a correct ROM image (3.0 is WInCE 5 as well, AFAIK).
I would suggest keeping the map for your location...
