v3.01 install
By jwbrenna · Aug 19, 2009in Hacks/Mods💬 12 posts👁️ 2,759 views
Posted Aug 19, 2009 · 06:32 UTC#1
Anybody nice enough to provide a detailed list of steps to update the hacked v3.0 to v3.01 for a F90BT.
a shortcut with files for download would be greatly appreciated (if needed)?????
The automatic update no longer works.
overwriting the hacked v3.0 files with pioneers factory v3.01 files (using v2.3 testmode) forces the unit to freeze at bootup.
I'm hoping an answer to this posting will fix my broken voice recognition system, it only recognizes music request but cannot recognize contact requests with my iPhone v3.01.
Thanks a lot!!!!!!!!!!1
Posted Aug 24, 2009 · 20:37 UTC#2
Same request here!
Thank you in advance for your help!
Posted Aug 24, 2009 · 21:57 UTC#3
Same here! Thank you!
Posted Sep 13, 2009 · 10:38 UTC#4
Same for me. Please look at it!!!!!!!!!!!!!!!!!!!!!!!!! :roll:
Posted Sep 14, 2009 · 03:09 UTC#5
i just overwrote the 3.0 files and overwrote/merged the 3.01 files and it was fine... make sure u delete the userdata folder on your avic or it will reboot. it will force a rebuild on next boot but u will have to reset all your settings as they will be default again.
this worked for me... try it if u like.
Posted Sep 14, 2009 · 05:19 UTC#6
Oke thanks, but can you tell where the files are or where we can get them. ???
Posted Sep 14, 2009 · 17:59 UTC#8
Thanks for the link. Is this also for EU F900BT you think or will it cause problems???
Posted Sep 14, 2009 · 18:49 UTC#9
to my knowledge just USA Version, you can try it but make sure u have a backup if it bricks your unit. I think 2.9 is the newest for EU.
- Dan
Posted Sep 14, 2009 · 19:20 UTC#10
oke, but i have now 3.000300 from this forum and it works fine, but always look for yhe latest update.
Thank you very much, i found it also on the dutch site.
Greatings Rob F900BT EU
Posted Sep 18, 2009 · 23:58 UTC#11
So I overwrote the 3.01 files into my flash disk. And I also deleted the userdata folder inside USER. When I boot up, it gave me a fatal error saying something about language. I forgot what it said exactly. Any help on this issue? Thanks.
Posted Sep 19, 2009 · 13:28 UTC#12
pioneers website under the downloads / updates section for the AVIC-X series. it will have the 3.01 update link.
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/GPS-Navigation-Systems/ci.AVIC-X910BT.Support?tab=B
Does this update WinCe too? Are there any modifications to the instructions or files in order to get this to work on an f90bt? thanks!
