Single DIN to Double DIN conversion
By simo_152 · Aug 21, 2009in General💬 6 posts👁️ 1,012 views
Posted Aug 21, 2009 · 01:55 UTC#1
I have an early 1980's mercedes and am wondering if it is even possible to install this unit (AVIC F310BT) in it
http://www.pioneer.com.au/Products/Navi ... 310BT.aspx
this is where it would go
http://i32.tinypic.com/9teiad.jpg
http://i29.tinypic.com/es6fmf.jpg
the stereo in there at the moment is just a detachable single din installed in like 2006, the pioneer unit is obviously a double din. below the stereo is the ashtray and cigarette lighter which is never used.
is this even doable?
cheers
Posted Aug 21, 2009 · 02:56 UTC#2
You should probably check on a Mercedes forum. They'd be more likely to know.
Posted Aug 21, 2009 · 16:09 UTC#3
any thing is possible with enough $$$, you would probably have enough room if you cut out the ashtray, you will probably have to heavly modify the dash to make it work and mount securely with a lot of fiberglassing, which is either gonna cost you a lot of time or a lot of money, again there is no such thing as "it dont fit" :)
Posted Aug 21, 2009 · 16:13 UTC#4
I just realized something, i am right handed and i cant do ANYTHING with my left hand, if i lived somewhere that had right hand drive cars, i would never be able to use my radio! haha :)
Posted Aug 25, 2009 · 03:49 UTC#6
It looks like there's enough room with ash tray removed. It also looks like it will be mounted very low in your dash.
