f900bt **system startup in progress please wait**
By piof900bt · Aug 22, 2009in Problems/Troubleshooting💬 10 posts👁️ 9,060 views
Posted Aug 22, 2009 · 16:45 UTC#1
my pioneer f900bt reboots after 5 min
Posted Aug 22, 2009 · 20:10 UTC#2
My F900bT Just Started Doing This
Comes on for about 5 minutes and reboots.
The system startup stays there I can still Play music buts it's really irritating.
i know how to enter testmode but what then ??? to solve this
what have i done
i followed this guide: ----http://www.avic411.com/forum/viewtopic.php?f=34&t=25751
this was succesfull but the i realized the maps are from us only and i live in the netherlands :(
After i saw this i delted everything in //myflashdisk in my unit.
and i didnt make a backup before so i called a friend who has the same device.
I have and entered his device in testmode and copyd his //myflashdisk to the sd card.
After this was finished i copied his back to my unit.
and gave my unit a reset then the system startup and the ****system startup in progress please wait**** bar doesnt go away and it will reboot after 5 min
i also tried to delete the gpsara 0,1,2,3
But this was also no solution for me
does anyone has the solution please
Posted Aug 23, 2009 · 09:44 UTC#3
nobody has a solution ????????????
Posted Aug 23, 2009 · 13:22 UTC#4
there is obviously something corrupt in the backup you created, you can try reloading it on to the sd card, ive found that doing mass file transfers using my cheap card reader that mass transfers will cause problems. try copying the backup one folder at a time to the card. apl, then apl2 etc
Posted Aug 23, 2009 · 16:01 UTC#5
i tried different pc' s different cards no solution :(
Posted Aug 23, 2009 · 19:01 UTC#6
yeah fixed finally
the solution was to use the winceig from an eu model
the ones found on this forum are all for usa models so it wont work with my system
and i have done an upgrade option 1 the one without format all clear now the bad is i have an older firmware but hey this one is better than 2.9 :)
Posted Jul 06, 2011 · 17:10 UTC#7
heej there, I have the same problem. The systems reboots and gives the same message. I also live in netherlands. Can you send me the files and instructions you used to fix the problem?
Thanx a lot!
Posted Apr 14, 2012 · 22:21 UTC#8
hi their guys i have the same problem could some one help....or send me the files and gives o how i can resolve this problem
thanks
Posted Aug 13, 2014 · 16:08 UTC#9
Need Help! i've an AVIC F-900BT installed the new software version 4.0 from 1.9 and now there's this message " system startup in progress please wait" that shows up all the time and restarts every 5mins
Posted Mar 21, 2015 · 13:03 UTC#10
can some one please help me ????
i have the same problem with my f900bt
