GPS Favorite backup from firmware v2 to v3 ???
By osisae · Aug 24, 2009in Hacks/Mods💬 23 posts👁️ 2,877 views
Posted Aug 24, 2009 · 01:35 UTC#1
If anybody know how to export GPS Favorite info to v3 after formatisation? I have all my files backup! Which file name on system is GPS favorite to replace it to new system?
Posted Aug 24, 2009 · 01:55 UTC#2
favourites.dat in the igo/user/userdata/save folder.
it may be in the apl2/user/userdata/save now that I think of it.
Posted Aug 24, 2009 · 05:09 UTC#3
My Flash Disk\User\UserData\iGO
EZRider from 3 picks up favorites.dat from 2.0 just fine.
Posted Aug 24, 2009 · 14:15 UTC#4
look before you leap, huh?! My bad...
Posted Aug 25, 2009 · 23:33 UTC#5
Thanx lads .I get back my favorites :D
Posted Oct 08, 2009 · 08:49 UTC#6
well, on my unit, my favourites were lost after the update (legit). Maybe because i clicked not to keep my boot screen. Anyway, thanks for the info, i will try to restore them from my backup
Posted Oct 08, 2009 · 15:46 UTC#7
Update wipes out everything in saved iGO preferences (those aren't compatible between 2 and 3), regardless of boot screen option. If you have the backup, just restore favorites.dat and you should be all set though.
Posted Oct 08, 2009 · 22:27 UTC#8
i'm a backup freak so i just have to find which is the most recent one:p
Posted Oct 18, 2009 · 14:40 UTC#9
My Favouites tab simply does not come on after the update....it is not highlighted so cannot click on it altogether...
Posted Oct 18, 2009 · 20:34 UTC#10
This is because your favorites.dat got overwritten with the upgrade, so there are no favorites saved. As explained, you need to take the favorites.dat file from your backup (you DID make a backup, right?) and copy it to the /user/userdata/save folder in MY Flash Disk.
-Eric
Posted Oct 20, 2009 · 16:37 UTC#11
no favouries.dat file in my backup
Posted Oct 20, 2009 · 17:19 UTC#12
-Eric
there is no file called favourites.dat in my user/userdata/save folder in my backup....i have 2 different backups of my f500bt flash disc........one on an external HD and one on my PC. Both backups dont have favourites.dat file in the user/userdata/igo/save
any ideas or suggestions wat i should do?
Posted Oct 20, 2009 · 17:51 UTC#13
Try looking in my flash drive\user\userdata\igo\save if you have any favourites then that is where they will be in favourites.dat. :)
Posted Oct 20, 2009 · 17:55 UTC#14
That is where i looked. There is no file by that name...not in my flash drive backup on my pc and not even on my F500 unit. I went to my flash drive\user\userdata\igo\save through wince as well and there is no favourite.dat file....
i basically have no favourite.dat file...not in my backup and not even in my unit....
pls help cause i need them favourites....thanks
Posted Oct 20, 2009 · 18:02 UTC#15
hm, might be a stupid question, but still: Did you ever add any favs and if yes, how exactly did you do it. You don't happen to look for the recent adresses? Those are in a different file - unfortunately I don't know, but it will be in save-folder and the name will content "recent" - I suppose.
Posted Oct 20, 2009 · 18:04 UTC#16
How about doing a search on your pc for favorites.dat?If it's not there then i think you're snookered. :(
Posted Oct 20, 2009 · 18:25 UTC#17
I never used my unit before the ezrider.exe hack. so never added any favorites when it was 2.006.
I did the hack as soon as i got the unit.
Posted Oct 20, 2009 · 19:17 UTC#18
so what do you need the favorites file for? There is no, if you never added any.
Posted Oct 20, 2009 · 20:01 UTC#19
i did. No file. Is there anyway i can use someone elses favourite.dat file on my system...would it work?
i could maybe just delete all the saved favourites and add my own?
Posted Oct 20, 2009 · 20:03 UTC#20
I got a brand new f500bt and loaded the 3.0 ezrider hack as soon as i got it...didnt use the unit before the hack as i needed to load an international map on it before i used the navigation
Posted Oct 20, 2009 · 21:37 UTC#21
Why would you need someone else's favorites file?
Are you sure you know what favorites are and how to use them? I'd suggest reading the manual a bit, then creating some of your own...
Posted Oct 21, 2009 · 07:24 UTC#22
When you add a location as a favorite it creates a file called favorites.dat.If you don't add any you won't create the file.You can have a copy of my favorites.dat if you like,you will then be able to navigate to my aunties house and my favorite fish and chip shop!!!! :):)
Posted Oct 22, 2009 · 10:09 UTC#23
Sorry people...didnt read the manual n therefore didnt know i have to save a favourite first through address or poi. I assumed that i would click on favourites and then be able to add as many once the favourites window is open....my bad. thanks for all your help. I have successfully added favourites to my f500bt.
