AVH-P6800DVD and PTR7
By Wicked3g · Nov 12, 2006in General💬 13 posts👁️ 5,281 views
Posted Nov 12, 2006 · 21:34 UTC#1
Has anyone used a PTR7 or TR-7 to bypass the brake checking on the 6800? If so could you explain the programming steps required?
As I understand it the 6800 requires you to hold the brake in, while pulling ebrake, releasing ebrake, then pulling ebrake again. Is it possible to simulate this kind of trigger on the ptr7?
Thanks in advance, sorry if this is an old topic, I can only find the instructions for the Z1 which doesn't sound like it's mimicking this same functionality.
_ny_
Posted Nov 13, 2006 · 02:49 UTC#2
Why's that sound exactly like the process for bypassing alpine systems. If that's really the case follow the instructions on the pac tr-7 for programming option 1.
Posted Nov 13, 2006 · 04:17 UTC#3
Don't know anything about programming the TR7 but this may help--It has nothing to do with the foot brake. It's just the parking brake-->On-Off-On. You can use a simple switch to simulate it if the TR7 is too complicated
Posted Nov 13, 2006 · 04:58 UTC#4
According to the TR-7 directions it's option #2, but it's also the factory default program shipped w/ the Tr-7... I'll give it a try. I would just put a switch there, but I'd rather make it automatic, and since I have a PTR7 I'll give that a shot first. I'll be installing everything Tuesday, so I'lll reply w/ the results in case if anyone else is wondering.
Posted Nov 13, 2006 · 05:07 UTC#5
If this is the case then the tr-7 would be connected like this ?:
Red -> Accessory 12v
Black -> Ground
Green -> Deck's remote turn on lead
White -> Deck's hand brake lead
blue -> not used
Does this sound correct?
Posted Nov 13, 2006 · 14:57 UTC#6
That should work. The white wire supplies a ground pulse then sits on ground in this configuration, correct?
Posted Nov 13, 2006 · 19:54 UTC#7
I believe so, there's no real explanation of what it does it's description is "Alpine Bypass" for that particular program type. But alpine would require pulse, then constant ground, so I'm assuming that's correct.
Posted Nov 13, 2006 · 22:05 UTC#8
I just finished installing a 6800 dvd in an H2, I used the TR-7 on the parking brake lead in Alpine format. Red to ign., black to ground, green to remote(blue/white), white to the light green parking brake lead of the 6800. Works like a champ, but you get the warning every now and then, just touch "OK" and it goes away.
Posted Nov 14, 2006 · 00:48 UTC#9
FANTASTICAL!!!!! Thanks for the update... your input is much appreciated. I wonder what causes the warning.
Does the warning come up during use or just when the bypassing sequence is done at boot up? It would be really annoying if my g/f was trying to watch a movie and a warning kept coming up on the screen.
Is there any pattern to when the warning comes up?
Posted Nov 14, 2006 · 13:17 UTC#10
The warning only comes up on boot. You may have to hit the "OK" icon on the screen, but only once.
Posted Nov 14, 2006 · 22:48 UTC#11
Nice.. thanks for the info
Posted Nov 15, 2006 · 22:10 UTC#12
Installed AVH-P6800DVD and PTR7 (peripheral) last night...
Works as expected using alpine bypass program #2
Warning seems like a standard warning, once hitting ok, there are no restrictions to the functionality of the deck even while driving.
Thanks for everyones input
Posted Dec 05, 2006 · 20:15 UTC#13
A tr7 module is not needed to bypass this head unit just a relay and diode are all that needed
Use the remote output (blue white)to switch a relay to switch ground to the park brake wire (light green) this will switch the green wire to ground after the headunit begins power up and allow all vidoe function to play
