by pass question
By warchild119 · Aug 25, 2009in General💬 7 posts👁️ 1,274 views
Posted Aug 25, 2009 · 02:54 UTC#1
i have a z2 installed with the wire by pass but now i bought a new hard drive with the updated maps and i'm not sure
if by installing this new drive will have any effect on the bypass.
can anyone help me with this confusion?
Posted Aug 25, 2009 · 03:25 UTC#2
If you have the 2 wire bypass, your upgraded drive should work fine. If you got the drive from me, then I KNOW it will work fine with the 2 wire bypass.
Posted Sep 05, 2009 · 05:22 UTC#3
Will the bypass work with a factory/locked drive? I have a Z2 (with the original hard drive) that I'm about to install in my car. I performed the two wire bypass. Do I need to upgrade to an unlocked drive for the bypass to work?
Posted Sep 05, 2009 · 23:17 UTC#4
Nope.
Posted Sep 05, 2009 · 23:45 UTC#5
Nope.
Thanks Garret. I'm glad it will work.
Posted Oct 27, 2009 · 07:36 UTC#6
Anyone have a good reference to do the bypass? I have garret's drive, but still get the warnings and the eventual blocking of the dvd playback, when I notch up the e-brake one notch while driving.
Posted Oct 27, 2009 · 12:55 UTC#7
See this post:
viewtopic.php?f=20&t=24033
If the bypass is done correctly, it WILL work.
