Z3 fan wont turn off
By Haz4rd · Aug 25, 2009in Problems/Troubleshooting💬 5 posts👁️ 740 views
Posted Aug 25, 2009 · 14:31 UTC#1
I got a problem with my Avic Z3, since i installed it on my car, i realized that the fan of Z3 never turns off, i push the AV button for 3sec and after the V button for turn off the system, is that right? I realized that my amps wont turn off too. Anyone know how can i fix it? I'm in Brazil and Pioneer doens't sell Z3 here.
Thank you.
Posted Aug 25, 2009 · 15:58 UTC#2
You can not turn it off unless you power off the vehicle. Check the following wires on the back of the Z:
Yellow: constant 12v+
Red: switched 12v+ (turns unit on/off with vehicle ignition)
Posted Aug 26, 2009 · 13:36 UTC#3
I just called to the guy who installed the Z on my car, and he said thast if he do by this way i can't turn on the Z when vehicle is off, is that true?
Posted Aug 26, 2009 · 13:58 UTC#4
Yes, that is true. You really do NOT want the Z running when the car is off, because it will kill your battery quick. If you want it to turn on with teh car off, then you need a secondary switch to power it competely off (which will turn off the fan) when not in use. This would be really hard on your battery, so I hope you have AAA :)
Posted Aug 26, 2009 · 20:25 UTC#5
Ok, so it happens with all Z3? I tough my Z was broken.
Anyone found a way to install Brasilian maps on Z already?
Ty
