I have a unit made before June 06 (think it is May but definetly before June). I have read alot of posts about greyed out buttons and the the tests to do on Ducati Boys website. The unit is on a '94 Corvette.
The problem is I only get full access to the menu buttons if I turn the ignition on and let the AVIC start up, then turn the key all the way to start the car. The buttons will remain accessible while driving.
If I start the car immedietly those buttons are greyed out and remain greyed out even after coming to a stop. I am 99.9% sure I have the ducati circuit hooked up right. The day/night mode works with the headlights turned on/off. The green parking brake wire is removed from the connector all together, also the speaker connector wires are removed from the connector. I have driven about 1500 miles so it is well calibrated.
If the day/night mode works the circuit should be working fine. The other suggestion I found was that the 12V red lead may be hooked to the 12V continous power....but this doesnt explain to me why I would have to wait for the unit to start up before I crank the ignition all the way to start the car. I also reset the unit from the resest button on the front panel with no change.
Any ideas?
