Using 7-Zip archive explorer, open "DATA.ZIP\ui_pioneer\800_480\ui\start_800_480.ui" in your editor. The layer to edit will depend upon which model you have (EW, AU, RE, or the UC model with MSN Direct). Ideally, you'll want to make the same changes to all 4 layers with the name "ui_AdvMenu*", just in case you didn't guess your model code right. I have an EC unit, so I edited the "ui_AdvMenuMsnd" layer.
Now we're going to want to edit the X positions for the first row of buttons (Address, POI and Favorites) to shift them to the left to make room for the new icon. I set the Address to "45", POI to "238" and Favorites to "432" to line them up with the icons below them. Next is to move the text for each button to the left as well. I set Address to "25", POI to "220" and Favorites to "412". Now we have room for our new button on the first row. I added the 2 lines below immediately after the ones for the "Delete Route" button:
Now save the file and quit the editor. Let 7-Zip update the copy in the archive.
Notes:
- [*:2nnuyzl3]I re-used the icon for the News icon from the MSN Direct screen for this (746_32K_MN-836_32b.bmp#3), someone with superior Photoshop or GIMP-fu is welcome to prep a better solution.
[*:2nnuyzl3]I re-used the script "sc_btnASM_LaunchFileMan" from my other post (
[*:2nnuyzl3]In case the other post gets deleted, the process I used to add a "File Manager" launch script in the official F90BT 3.0 (iGo 8.3) DATA.zip:
[*:2nnuyzl3]Using 7Zip, I opened DATA.ZIP (Right click, select "7-Zip"->"Open Archive" from the context menu)
[*:2nnuyzl3]In the 7-Zip file manager, navigate to the ui_pioneer\common\ui folder. Highlight "advmenu.ui" and hit F4 on your keyboard to edit the file with your configured editor. I used vim so it would let me forcibly overwrite the file.
[*:2nnuyzl3]At the bottom of the file, I added the following lines:
;!!!fourg adding FileMan launch script, replace the command below with your favorite
[*:2nnuyzl3]Force-save the file (in vim, this is :w!) so 7-zip will detect the file has been updated.
[*:2nnuyzl3]Quit the editor
[*:2nnuyzl3]7-Zip will prompt you that "File 'advmenu.ui' was modified. Do you want to update it in the archive?". Click OK to update the .zip file's copy with your changes.
Boot into test mode and copy DATA.zip over to "My Flash Disk\APL2\iGo" after making a backup of the original DATA.zip (I usually rename it to DATA_orig.zip or something similar).
