IP Bus cable question...
By fe342185 · Aug 27, 2009in General💬 2 posts👁️ 917 views
Posted Aug 27, 2009 · 01:15 UTC#1
I just got my XM module today. The IP Bus cable has the power cable wrapped with it. Is the power and ground being used by the IP Bus cable?
I have an HD Radio currently with the IP Bus cable already installed. Since the installation guide requires the HD radio to be plugged into the XM module then to the HU, can I use the same IPBus cable I ran for the HD radio? The IPBus cable that came with the XM module will be used to connect between the HD radio and XM module.
Posted Aug 27, 2009 · 01:45 UTC#2
Yes, it should work fine as the cables should be identical.
