3.0 Update AVIC F90BT - Missing St Names
By jonbruce · Aug 28, 2009in Problems/Troubleshooting💬 7 posts👁️ 1,571 views
Posted Aug 28, 2009 · 02:20 UTC#1
I no longer have street names on my 3D projection maps, but I do on my 2D maps since I ran, I believe successfully the 3.0 update. Any else run into this and has a possible solution?
Posted Aug 28, 2009 · 11:37 UTC#2
This is a common problem. You have to set the scale to 500 feet or less.
Posted Aug 28, 2009 · 13:05 UTC#3
Thank you! - i will test this and let you know.
Posted Aug 28, 2009 · 15:18 UTC#4
I can't get mine to go below 1,000 feet? Any suggestions? :x
Posted Aug 29, 2009 · 03:51 UTC#5
I did this, and it worked. Two questions.
- I didn't have to do this with the previous version?
- How do I save this setting?
Posted Aug 31, 2009 · 01:35 UTC#6
Go into navi settings then go into display settings and change the value.
Posted Sep 05, 2009 · 18:44 UTC#7
Will this fix let the street names be displayed at 1000ft?
