I f I upgrade to ver 3 can I
1. still use the testmode files I used to edit data.zip for software bypass
2. still use the avic phone book editor I found here
http://avic411.com/forum/viewtopic.php? ... is#p152569
thanks
thanks
1. Yes, testmode 2.3 is compatible to boot with 3.x. You will need however a different data.zip matching to igo 8.3.x.
2. The below mentioned website is reported as you see in the attached image. SQLite Expert Personal Edition (freeware) is working fine with the phonebook.db file.
I f I upgrade to ver 3 can I1. still use the testmode files I used to edit data.zip for software bypass
viewtopic.php?f=34&t=22601&p=152569&hilit=exovis#p152569
thanks
thank you, think I will upgrade
