Hello everyone, I used to have a Z1 that was hooked up to a CDX-P1280 cd changer, unfortunatly my Z1 was stolen so I got a new Z110BT as a replacement but now the cd changer no longer functions as there is no "multi cd" touchscreen button on the new unit. Is there a way of still using my cd changer with this system as one of the aux options? Any assistance s greatly appreciated! Thanks!
Using CDX-P1280 changer with Z110BT
Nope. They dumped changer control last year with the F-series. Gotta put all your CDs on an ipod, USB device, SD card, or other mp3 player
So it sounds like the XDV-P6 will not work with the Z110 as well.
It will, I have a D3 connected w/ a Japan MD changer and XDV-P6 connected to the EXT1 and EXT2.
Isn't the D3 listed as compatible with the XDV-P6. So how does this tell us that the Z110 work with it?
You have to set the xdv-p6 to autoplay, then you can select what disc you want to play. Only controls are the disc numbers, ff and rr..... << >> on the touch screen. Remote doesn't work thru the head unit--don't bother calling Pioneer they don't know.
Also, set the AV1 or AV2 to EXT, That way when you select either i will show video. Connect the ip-bus and video rca input. To operate you will select EXT 1 or EXT 2 not AV. Most likely the idea is to choose AV2 to ext since the ipod is set in AV1 to ipod. I will be getting the Z110bt soon. Need to sell my D3
Thanks for your help regarding using a cd changer, I let me insurance company know and they reimbursed me the cost of the cd changer and labor also because it nolonger functions due to the new navi system.
