Is it possible to put a bluetooth button on the main map screen to access the phone? Pushing that volume knob is tricky to do when your driving a Subaru.
Posted Aug 29, 2009 · 01:25 UTC#1
yes but it's also tricky, lets say you start your unit and went straight to navi, if you have the phone button in there once you click it would go to phone settings, but, let's say when you started your unit and then you went to phone settings and clicked the dial pad and just canceled it by pressing the map, when you press the shortcut button on the map you it will bring you to the dial pad screen, so whatever was the last state in the phone settings whenever you press the shortcut for the phone it will go there
