F500BT testmode problem
By buddhabar · Aug 29, 2009in Hacks/Mods💬 4 posts👁️ 2,350 views
Posted Aug 29, 2009 · 12:48 UTC#1
Hi!
I have a F500BT EU vers. and last week I got from PioneerCNSD-150FM so I have 3.0x and map from 2009. I tried to use testmode and downloaded testmode.zip 2.3 , unzipped and moved 2 files to SD card. when i start my f500 with sd card nothing happening. I don`t understand what i should do for it.
thanks
Posted Aug 29, 2009 · 13:58 UTC#2
You need to have the 'testmode' folder copied to the sd card as it is extracted on your pc. So the root of your sd card has a 'testmode' folder and inside that the nntestmode.exe, mortscript.exe, all the numbered files etc etc..
Posted Aug 30, 2009 · 10:59 UTC#3
I Just wondering if I can use the orginal sd from pioneer 3.01 to copy pc and modificate on those files?? in this case I don`t need "testmode" or?????
Posted Aug 30, 2009 · 13:33 UTC#4
Testmode will allow you to back up whats on your device before updating. If you don't care about that, you can for example replace the original data.zip & ezrider.exe on the update sd card with a modified one, and the upgrade will copy your new ones. In that case yes, you don't need test mode.
Make sure to back up the originals SD cards content first at least..
