Thanks for all the advice.. I'm probably going to keep the factory amp for now and c how it sounds. I would like to eventually put a 4 channel amp on the bose speakers the only drawback i've been hearing is its hard to get your onstar to play through the speakes when you add an amp to system.
If you're going to add a 4channel amp.... you have to upgrade the speakers....
I know your truck inside an out - have done serisouly 100's of installs on them since they came out in 2000.... even though they are bose speakers - they're still paper speakers - nothing high quality - trust me....
If you want good speakers with a good price - look at the Polk DB's or the Pioneer PRS / D series - they're very well priced take only about 50-75 watts... so you don't need an $$$ amp and the sound quality is amazing. If you add a sub to your factory system you'll be perfectly happy with what you hear, as long as you turn on your HPF - high pass filter on 80 or 100hz or even up to 125... as long as they don't distort and the rest of the frequency will go to your sub.
Don't waste your time amp'ing the factory bose speaers - its a waste of time and you'll burn them within days if not instantly.....
Also check out the ALPINE PDX amps - they make an awesome 5channel amp..... super small - super clear - perfect for your application and you can easily hide that amp under a seat or drill it on your back wall !!!!
You can add a speaker to your PAC inteface to still hear the door chime - its pretty small, you an put it in your dash or kick panel or under your steeringwheel.... where ever you pref...
