GreatRock said:
I got harness from installer.com, that is for volkswagen. and antenna connectoe too.
I am going to follow Pioneer manual.
And I got cadillac diagram from cadillacfaq.com. Now I am about to connect. Please give me any info what I miss. And would you explain how "Databus sucks" mean?
Yah, that harness says it from Volkeswagon, but it lists that the 04,05 Cadilac CTS also uses the same harness. I don't know if it does or not, that's a weird collection of vehicles which use the same harness.
As for "databus sucks" I think he is referring to the fact that some cars are now sending audio information to seperate amplifiers somewhere else in the car, no via analog audio lines (the rca jacks on your new head unit) but via a databus. I believe most cars use CANBUS or something like that... or that most cars that use this feature, use canbus.
http://www.launch-techs.com/Support/Info/can-bus.htm
http://en.wikipedia.org/wiki/CAN-bus
If your speakers are connected to an external amp, and not to the head unit and all that goes from the head unit to the amp is that canbus interface, then wiring up speakers from the head unit will suck.
If there are lines directly to the speakers from your head unit area, I don't think you will have a problem. But I have never worked on a cadilac.
