d3 in gmc denali- no sound
By amsugg · Aug 30, 2009in Problems/Troubleshooting💬 8 posts👁️ 2,271 views
Posted Aug 30, 2009 · 23:31 UTC#1
bought a d3, bought all the adapters and harnesses that it said i needed did the install and i have no sound. i have searched this site read all the no sound posts, tried everything everyone else tried and still no sound. did some looking on gmc forum, someone said i had to access the speaker wires from a different harness below where the radio is located to bypass the bose amp. is this my only option? can i not tap into and use the bose amp? i was also confused cause with the harness i purchased it said i should of used R.C.A's but there where no R.C.A's on my factory unit. so i cut the ends off and ran them like normal. can anyone help me? if this has already been covered please give me the link to the thread. thanks in advance.
Posted Aug 31, 2009 · 00:00 UTC#2
also is it possible i was given the wrong interface kit? i thought the reason for the kit was to keep my door chimes and on-star and things like that. how ever not i have two door chimes the factory one and the one on the integration harness. kit i was given is made by scosche and part number is gmlan2sr
Posted Sep 01, 2009 · 18:22 UTC#3
update-
power is getting to amp regardless of head unit. i jumped from LR speaker on the back of aftermarket h/u to LR speaker coming out of the amp and all the speakers worked. so aperently there is no signal from h/u as maybe some pins arent right any idea?
Posted Sep 01, 2009 · 18:47 UTC#4
It would help by telling us what interface you used. Should have been a gmos-04 from metra or similar. Denali and Cadillacs have a digital amp turn on, versus a standard Yukon. You do not cut the rca's off and run speaker level into it, the factory deck not having preout rca's has nothing to do with it.
Get the proper interface, and follow the directions.
Posted Sep 06, 2009 · 19:29 UTC#5
dont have proper bose harness so sound to the speakers
Posted Sep 09, 2009 · 17:34 UTC#6
FWIW, he DID say what interface he used...
Posted Sep 11, 2009 · 13:49 UTC#7
update
they deff gave me the wrong harness. did a little reasearch and took it back and got the right harness gmos-04
Posted Sep 16, 2009 · 18:03 UTC#8
the year of the Denali will make a hugh difference in which hanrness you will have to use, also you may need to cycle the onstar on and off berfore it will work
