avic-n2 bypass pictures please
By bulldawg3111 · Nov 14, 2006in Hacks/Mods💬 14 posts👁️ 4,176 views
Posted Nov 14, 2006 · 05:56 UTC#1
I just got a new N2 and I am trying to do the bypass. However I do not see the silver sticker to peel on the back of the headunit. I have removed the cage and the only thing I see uner the cage is a silver metal plate that can be removed with two screws. I removed this silver metal plate, but the only thing that is under it is a ribbon cord, not the R197 pins. This silver metal plate is at the very front of the head unit under the cage. Could someone please post a picture of the entire head unit and the silver sticker. I saw some of the other pictures of the R197 pins but they are so zoomed in that I cannot tell their location relative to the headunit. Thanks for any help.
Posted Nov 14, 2006 · 11:14 UTC#2
This is a pic of the N3, but the sticker is in the same spot on both units
Posted Nov 14, 2006 · 17:20 UTC#3
Can you take a picture that is zoomed out so I can see the relative location on the unit. Or can you try and explain the exact location of the sticker on the unit. Thanks
Posted Nov 14, 2006 · 17:41 UTC#4
Ummm, Its right above the big white sticker that says PIONEER on the bottom of the head unit
Posted Nov 14, 2006 · 21:36 UTC#5
LOLOL! I thought the picture might have given this insight ;)
Posted Nov 15, 2006 · 04:47 UTC#6
Well I guess my unit does not have the sticker or hole for the R197 pins. I have a factory refurbished unit. It is any chance thay may have put a different metal casing around the head unit? Does the N1, N2, and N3 all have this hole for the R197 pins? I wil get a digital cam later and take a picture of the bottom of my unit. This will really be a wrench if I can't bypass the unit.
Posted Nov 15, 2006 · 21:58 UTC#7
Yes. The N3, though, does not have the pins, rather Pioneer made it much easier and simply put a flip switch underneath the sticker ;)
Posted Nov 16, 2006 · 00:55 UTC#8
Here is a pic of the bottom of my n2. They metal cage has been removed. So where is the silver sticker?
Posted Nov 16, 2006 · 01:06 UTC#9
Have you tried peeling back either of the 2 stickers in the red squares?
Posted Nov 16, 2006 · 03:01 UTC#10
No, the R197 pins are not under either of those stickers. There is a hole hidden under the Pioneer sticker on the right but it is not shaped like the hole from previous pictures that I have seen on the forum, and I don't see R197 pins in this hole. Help??????????
Posted Nov 20, 2006 · 02:32 UTC#11
Off topic, where did you get the reconditioned avic?
Posted Dec 03, 2006 · 19:41 UTC#12
take your index finger and feel the top part of the pioneer sticker on the right. if u feel a opening bigger thena screw then bingo.
Posted Dec 04, 2006 · 01:22 UTC#13
I believe recondition units have N1 cases to prevent from easy-access tampering. Probably have to do what N1 guys do, and disassemble everything to get to the mainboard.
Posted Dec 08, 2006 · 06:20 UTC#14
My refurbished unit looked just like that. If I recall correctly the sticker was on the other side. It was plain white though, did not have VOID all over it.
