Hello,
I have Z110BT and when I get incoming phone call using bluetooth, it doesn't mute the music. Does anyone know how to set up? to mute it automatically?
Hello,
this is from the uk manual
Touch [Mute] on the “AV System Settings”
menu.
Each touch of [Mute] changes the settings as
follows:
! Guide/Tel/VR—The volume is muted or attenuated
according to the following conditions
— When the navigation outputs the guidance
voice.
— When you use a mobile phone via Bluetooth
technology (dialling, talking, incoming
call).
— When the voice recognition mode is activated.
! Tel/VR— The volume is muted or attenuated
call).
! Off—The volume does not change
p Operation returns to normal when th
Is there a way to turn the music lower even further after you have already answeredthe call? Sometimes I have the radio up and the 20db setting still seems loud. I have it set to mute during a call now but I preferred the lowring option.
You can set it to 10db.
