Copy of My Flash Drive
By ovalball · Sep 03, 2009in Hacks/Mods💬 3 posts👁️ 1,078 views
Posted Sep 03, 2009 · 10:01 UTC#1
If I delete my Flash drive from my F900BT,then replace it with some other members My flash drive.....will it work?Sorry if it that question is painfully obvious to the more experienced hackers on here. :?
Posted Sep 03, 2009 · 23:58 UTC#2
You should be ok as long as the new "My Flash Drive" is from a F900BT and has every file needed. If you try it you should definitely have your current "My Flash Drive" backed up on your computer so that you have something to go back to if things don't work for some reason.
Posted Sep 04, 2009 · 04:18 UTC#3
It will work just fine. I know of people that have used the f90bt flash disk back up on their f900bt. The only thing is that it deffinatly can not be the f500bt back up.
