There has been quite some speculation on how the 900/910 units navigate using pulse...
I was curious as to whether anybody really knows how it works ?....
On the other Pioneer units (Z1,2,3, D3) if you have pulse (Vss) hooked up, the primary source for navigation is then pulse and gyroscope, and GPS is only used for corrections (and initial positioning)
On the 900 series, people have speculated that it always uses GPS, and only falls back on pulse & gyroscope when the GPS signal is lost....This would be different from the way Pioneer worked in the past...
It would seem to be a missed opportunity, as in principle navigating with pulse and gyroscope is more accurate (and more responsive certainly at higher speeds), and the hardware is present in the 900/910.
Thoughts/information anyone ? ![]()
