warning distance / alert distance
By navigarie · Sep 06, 2009in Hacks/Mods💬 3 posts👁️ 724 views
Posted Sep 06, 2009 · 19:19 UTC#1
Can somebody tell me wich code i have to use and wich ui-files to change for the alert - distance and the warning - distance for version 3.0.
I,am looking for it a long time and tried to put the code in my own data.zip but it is to complecated for me to understand all of them.
Do i only have to look in the setting_800_480.ui and speedcam_800_480.ui
Please can sombody help me.
Regards,
Navigarie.navigarie
Private message
Posted Sep 06, 2009 · 21:08 UTC#2
I think it is in SYS.TXT
[warning]
approach_beep_distances=8,16,24
warn_distances=60:500,40:300 ;(110:1000, 80:800, 60:500, 40:300)
just play around with the values and set them to the Limits used in your country
Haven't tested myself
Jörg
Posted Sep 09, 2009 · 08:37 UTC#3
Thank you.
I Will test it.
I have been looking in the ui-files if it is possible to implement the alert distance slider wich is in div. mods on this forum, But for me this is to complicated to understand.
I use the standard EU v3.02 firmware / Data.zip with the mute / linear compass mod.
Maybe some-one can give me the exact code / files i have to change it would be appreciated.
Sorry if my english is not perfect.
regards,
navigarie.
