F90 boots into destination Tab
By greydragon · Sep 07, 2009in Problems/Troubleshooting💬 2 posts👁️ 751 views
Posted Sep 07, 2009 · 00:59 UTC#1
Hello,
I have an F90BT and after I updated the unit with new 3.0 from pioneer, it will boot into the destination Tab?
I'm not sure why, and it doesn't allways do it. Install went flawlessly. Has anyone run into this issue, is their a fix or hack that I can perhaps use to fix the situation. I know how to use test mode and swap files but don't like to do it without some direction. Does anyone have a sugestion on what file I may have to replace?
Thanks for any help you guys may have. :?
Posted Sep 10, 2009 · 01:40 UTC#2
I have the same problem intermittently. No solution at this point. After I shut down and restart it is usually OK. Really a PITA though.
