Anyone out there have UBOOT.CKS
By Edwez1 · Sep 08, 2009in Problems/Troubleshooting💬 11 posts👁️ 7,945 views
Posted Sep 08, 2009 · 00:15 UTC#1
I am having a issue with my avic f900bt and i am 99 percent sure i need the files for uboot.cks and uboot.bin. I do a uboot test in the service menu and its supposed to say good, but when i do it it says bad. Which is why i feel that is the issue i have. It does not boot up at all, buttons light up for like 15 secs and nothing. I have gotten to the point of what i think uboot disappearing. I cant use testmode at all either, none of them. Anyone have these files stashed somewhere a pm with the link would be greatly appreciated!!! Thanks in advance
Posted Sep 08, 2009 · 06:43 UTC#2
I do not have what you ask for, but trying to troubleshoot your problem.
Did you try to flash the correct wince file via the service menu?
Posted Sep 08, 2009 · 13:26 UTC#3
Yeah it just stops. I think the uboot is like bios in a computer, uboot is basically what starts the unit up in its first stages so i think without uboot being available the unit will not do anything properly. All i wanna do is get the damn thing into test mode lol!!! Let this be a lesson, dont install any hacked versions of software, cuz obviously after a month of working great it obviously crashed out of nowhere. I wish i could fix this thing, its really annoying not having sound.
Posted Sep 08, 2009 · 13:27 UTC#4
ANd when i mean it just stops it says reading and gets to writing and stops after 6 percent.
Posted Sep 08, 2009 · 14:12 UTC#5
If you're getting errors while flashing the wince image from the service menu and you can confirm that your source ie.SD card is good and readable - then you probably have a flash memory hardware problem and it will need servicing.
Posted Sep 09, 2009 · 01:19 UTC#6
You dont think its a uboot problem since when i do a uboot test it is the only thing that comes back saying bad?
Posted Sep 09, 2009 · 05:15 UTC#7
The uboot problem saying bad may well be for exactly the same reason. A uboot will not just 'get bad' by software. If it became corrupt by itself, then probably hardware failed.
Only cases where it can get corrupt/respond badly are:
1. A hardware failure.
2. It was flashed by a wrong file.
3. The flash process was interrupted inadvertently eg. power failure in the middle of flashing etc.
Did case 2 or 3 happen? If yes then you have a chance. If no then its case 1.
I tend to believe it is a hardware failure, especially because you said wince flashing does start but fails as well, however there's no harm trying of course if you get the correct uboot file. Just don't miss on a possible warranty cover just by waiting for someone to post it..
Posted Sep 09, 2009 · 13:05 UTC#8
Very true. nah i was giving it a few days to see if maybe someone actually had the necessary uboot files. I was actually able to retrieve half but still need the uboot.cks file. Its been way too long though, i need my radio fixed lol. Its going back the sketchy warranty repair at pioneer today lol. ANd no 2 or 3 did not happen. I did however have the beta 3.0 software that wsa up on this site for like a month. But if there was a problem then it woulda showed from the beginning of the install correct? It shouldnt work for a month and then just stop booting out of nowhere. Oh well thanks for your help. And to anyone reading this, good luck to anyone trying to find the uboot files!!!!!
Posted Dec 02, 2010 · 22:54 UTC#9
I am having the EXACT same problems. I upgraded to 3.0, it worked for about a month, and then crashed. My F90BT lights up the knob and menu/map buttons for about 15 seconds, then it all goes black. No splash screen, no nothing. The uBoot test also returns "bad". Please help!
Posted May 30, 2012 · 22:11 UTC#10
Hi, i have the same issue.. did you fixed your issue?
thx for your infos
Posted Jan 29, 2013 · 22:30 UTC#11
please when you obtain from UBOOT TEST : "BAD", what steeps must to be follow to repair the damage?, im very unguished, my poor radio is bricked
