Transparent background BMP's
By diaftia · Sep 08, 2009in Hacks/Mods💬 5 posts👁️ 1,246 views
Posted Sep 08, 2009 · 06:22 UTC#1
I am racking my brain here. I am using Photoshop CS3 and its a tool that I have not exactly mastered. I have searched and all I have found is that I need to use an alpha mask. Problem is more searching doesnt seem to lead me to a way to do this. I have a new layer, I have moved it down below my existing one, and I either get a white background or no image at all. I need to make the background of my image transparent. What is the best way to go about doing this in PS-CS3? If I open the file back up after saving it should show up with a checkerboard background correct?
Thanks,
Alex
Posted Sep 08, 2009 · 15:42 UTC#2
Thanks,
Alex
if the file has a checked background it would show as black or white or may not even show on screen, the best way is to have that checkered part masked
Posted Sep 08, 2009 · 15:46 UTC#3
To make a transparent bitmap you must make sure that the bitmap has been converted to Indexed 256 colour. 24bit Bitmaps will not make a transparent image. Make sure that pixel (0,0) in the top left most part of thepicture has the colour you want to be transparent.
If you have a background colour that you do not want to be transparent put another colour at pixel (0,0), preferably 1 that doesn't appear in the rest of the image. Someimage allow you to add a colour to the palette if needed.
In some cases setting colour 0 in the colour index also can help.
Posted Sep 08, 2009 · 17:04 UTC#4
Wow, I need to take a photoshop class apparently as this is all a foreign language to me. ;)
When I go to image/mode indexed color is grayed out. And when I try to go new image, bitmap it wont let me create a transparent background. I guess this is just going to require a lot of back and fourth trial and error.
Posted Sep 08, 2009 · 18:51 UTC#5
Ah! I got it! I had to create the image with a transparent background. Then convert the main layer to a background layer. Once I did that I went into the channels tab and created a new channel as an Alpha layer. They key was to do the edits I needed on that layer which then started to show in the avic.
