Boris, forgive my software coding ignorance, but how to I add the visible model to the scripts being passed?
Here is the first script:
RUNIF vActualFieldValue "1" 'run sc_NMS_SetSpeed "navigation.distance_to_destination.number_text" "navigation.distance_to_destination.valid|ui.vOnFlyover" "navigation.distance_to_destination.unit_text"'
ELSE_RUNIF vActualFieldValue "5" 'run sc_NMS_SetSpeed "navigation.distance_to_waypoint.number_text" "navigation.distance_to_waypoint.valid|ui.vOnFlyover" "navigation.distance_to_waypoint.unit_text"'
ELSE_RUNIF vActualFieldValue "8" 'run sc_NMS_SetSpeed "navigation.current_speed.number_text" "navigation.current_speed.valid|ui.vOnFlyover" "navigation.current_speed.unit_text"'
ELSE_RUNIF vActualFieldValue "9" 'run sc_NMS_SetSpeed "navigation.current_speed_limit.number_text" "navigation.current_speed_limit.valid|ui.vOnFlyover&navigation.current_speed_limit.valid" "navigation.current_speed_limit.unit_text"'
ELSE_RUNIF vActualFieldValue "2" 'run sc_NMS_SetTimeSpan "navigation.time_to_destination" "navigation.time_to_destination.valid|ui.vOnFlyover"'
ELSE_RUNIF vActualFieldValue "4" 'run sc_NMS_SetTimeSpan "navigation.time_to_waypoint" "navigation.time_to_waypoint.valid|ui.vOnFlyover"'
ELSE_RUNIF vActualFieldValue "7" 'run sc_NMS_SetTimeSpan "navigation.time_to_manuver" "navigation.time_to_manuver.valid|ui.vOnFlyover"'
ELSE_RUNIF vActualFieldValue "3" 'run sc_NMS_SetTime "navigation.eta_at_destination" "navigation.eta_at_destination.valid|ui.vOnFlyover"'
ELSE_RUNIF vActualFieldValue "6" 'run sc_NMS_SetTime "navigation.eta_at_waypoint" "navigation.eta_at_waypoint.valid|ui.vOnFlyover"'
ELSE_RUNIF vActualFieldValue "10" 'run sc_NMS_SetTime "gps.current_time" "gps.current_time.valid|ui.vOnFlyover"'
ELSE_RUNIF vActualFieldValue "11" 'run sc_NMS_SetSpeed "navigation.current_altitude.number_text" "navigation.current_altitude.valid|ui.vOnFlyover" "navigation.current_altitude.unit_text"'
ELSE_RUNIF vActualFieldValue "" 'run sc_NMS_ClearField'
Here is the second:
vTmp.set $1
vValid.set $2
vTmp2.set $3
RUNIF vActualField "1" 'txt_NMRText1_num.DROPMODEL, txt_NMRText1_num.textmodel_wstr vTmp, txt_NMRText1_num.visiblemodel vValid'
RUNIF vActualField "1" 'txt_NMRText1_unit.DROPMODEL, txt_NMRText1_unit.textmodel_wstr vTmp2, txt_NMRText1_unit.visiblemodel vValid'
RUNIF vActualField "2" 'txt_NMRText2_num.DROPMODEL, txt_NMRText2_num.textmodel_wstr vTmp, txt_NMRText2_num.visiblemodel vValid'
RUNIF vActualField "2" 'txt_NMRText2_unit.DROPMODEL, txt_NMRText2_unit.textmodel_wstr vTmp2, txt_NMRText2_unit.visiblemodel vValid'
;run sc_FullScreen
I see reference to a visible model in the second script, but I am not sure how to actually add in the condition.
As always, your help is much appreciated.
