Bluetooth issues w/ iPhone 3G
By Scott8659 · Sep 09, 2009in General💬 20 posts👁️ 3,070 views
Posted Sep 09, 2009 · 00:47 UTC#1
I just installed my Z110 but I'm having serious issues with the Bluetooth and Bluetooth audio. When I try to play music via Bluetooth audio it keeps cutting in and out. It does this no matter where the phone is located. I tried re-pairing but the problem got worse. I also noticed my iPhone is only pairing as a Bluetooth audio device and everytime I try to make a call I get a message that the audio device will be disconnected. I tried deleting the entry for my phone but it appears you cannot delete anything until you have 5 phones paired. When I select the registration option all I get is a menu to setup a new device. My phone is not even lisyed and there is no option to delete. Any ideas?
Posted Sep 09, 2009 · 07:21 UTC#2
The problem your having with the audio cutting in and out is a bug with the phone. Mine does the same thing and also did it with the DNX9140. I also had the same problem with the phone not pairing properly for hands free. Delete the unit profile on the phone and repair from the phone.
Posted Sep 09, 2009 · 13:32 UTC#3
That sucks. Hopefully it will be fixed with the software update planned for this month. Have you found any way to delete the profiles from the HU itself?
Posted Sep 09, 2009 · 18:00 UTC#4
Yea its in there somewhere. I had to fix the problem you are having also last week and I was able to delete the profile of my phone from the unit. Page 80 in the manual.
Posted Sep 09, 2009 · 18:38 UTC#5
I tried that last night but never get the option to delete. It always tries to register a new device. How many phones did you have linked when you deleted one?
Posted Sep 10, 2009 · 00:20 UTC#6
as far as using the bluetooth for making phone calls I have a 3gs and it works flawless, I dont use the bluetooth audio portion,(use regular iPod for music) I never liked the quality of the audio no matter what radio or device, the easiest way to delete the phone from the radio is to do method 2 ,which is the "restore to factory settings" button in the "settings" menu. this will erase some other settings but will also erase paired phones. i'm running 3.01 software on iPhone and it works fine, my only gripe is that u gotta goto the NAV screen and hit the OK button before the voice dial will work, I just updated to 3.1 but have not tried it yet with that. Apple did not list any bluetooth updates with 3.1 so it should still work the same. Also used the pair from phone option on the Z
Posted Sep 10, 2009 · 01:09 UTC#7
Last I heard was v3.1 was supposed to include the Bluetooth profile that allows remote control via A2DP.
Posted Sep 10, 2009 · 03:41 UTC#8
that would be cool for people who use it for streaming, but i read the details for the download and i didnt see anything about bluetooth, might have just missed it though. haven't got in car yet since 3.1 update. i do know that you could always play/pause with 3.0 but no track changing
Posted Sep 12, 2009 · 22:34 UTC#9
Anyone having problems connecting with Iphone since the new 3.1 update? I have heard mixed reviews that some haven't been able to connect...
Posted Sep 12, 2009 · 23:38 UTC#10
I tested a friends 3GS yesterday with my unit and everything worked flawlessly, even charging of the phone which some have said doesn't work for them.
Posted Sep 12, 2009 · 23:39 UTC#11
Try to repair from the phone.
Posted Sep 12, 2009 · 23:43 UTC#12
Thanks! Did your friends phone have the new update? Just curious...
Posted Sep 12, 2009 · 23:44 UTC#13
Actually it only had 3.0.1 so there may be some truth to the problem with 3.1
Posted Sep 12, 2009 · 23:48 UTC#14
Yeah, I am getting closer and closer to buying it and its making me a little nervous that it won't work with my phone.
i am sure eventually it will be compatible but that would suck everytime you update the phone your bluetooth stopped working.
Posted Sep 12, 2009 · 23:51 UTC#15
Try to find someone with the unit or go to your nearest dealer that has one is his board. You should be able to pair it and do full testing to verify compatibility.
Posted Sep 12, 2009 · 23:56 UTC#16
Sounds good! I will take a drive to a few of the local places. Thanks.
Posted Sep 13, 2009 · 15:04 UTC#17
iPhone 3gs with 3.1 work flawless , have never had any issues with 3gs iPhone on unit as far as bluetooth phone call, never use it for bluetooth streaming or charging, have regular iPod for music that stays plugged in inside glovebox
Also you should always delete or at least re-pair phone when you do a software update
Posted Sep 13, 2009 · 22:07 UTC#18
Very good to hear! Thanks so much for the info...
Posted Oct 06, 2009 · 22:21 UTC#19
Be careful of your expectations with the iPhone and Bluetooth A2DP. Before June '09 (a year after it's release and a week before the 3GS came out) the 3G could only do bluetooth phone calls (unbelieveable for the price, yeah I know) the 3GS came with the A2DP feature out the box so i would expect it to work better. But my 3G goes in and out alot on my 980BT where my Tilt worked great, even could skip forward & back with the remote. Even with my A2DP earpiece, I have to hold the phone, if i put it in my pocket, audio in and out. Give Apple a little time, after enough complaints it should work better for more people.
The best way to test the unit is to try another phone if available.
My Z should be here Friday, I can't wait. :mrgreen:
Posted Oct 06, 2009 · 23:51 UTC#20
Unfortunately the iphone still has that issue with bluetooth audio. It tends to skip a lot.
