Changing things
By SCprez · Sep 09, 2009in Hacks/Mods💬 5 posts👁️ 1,049 views
Posted Sep 09, 2009 · 05:59 UTC#1
hello everyone.
i just started hacking my f900bt. is the a way of change the font and possible text colors. also is there a way to change what thins say. like the first screen says top menu. is there anyway to change that?
Thanks guys for any help
Posted Sep 09, 2009 · 11:32 UTC#2
I also want to know that.
I have an Idea, that if you supress the text by code, and in the place you put an image with the text that you want, then you can get that effect.
But I don´t know if it´s possible or if there´s a easier way of doing so.
Check my post where we are talking about the same issue:
viewtopic.php?f=34&t=27125&p=187289#p187289
Is that kinda what you want?
Posted Sep 14, 2009 · 13:02 UTC#3
Hi, I am trying to disable the parking brake requirement to add addresses to the nav. It is a major pain. Any ideas how to.
Posted Sep 14, 2009 · 15:03 UTC#4
use the search function
Posted Sep 25, 2009 · 18:34 UTC#5
There is a green wire that has to be connected to the wiring of the parking brake. Remove it and connect to ground.
