Factory camera with z110
By ekaz · Sep 10, 2009in Problems/Troubleshooting💬 3 posts👁️ 1,545 views
Posted Sep 10, 2009 · 15:05 UTC#1
I have a factory reverse camera that I want to use with the z110. I have identified the wires, there are only 3 wires, signal, return, and shield. I'd assume that I can connect signal to the pin on an RCA and the shield wire to the ground of an RCA. Does anyone know what the return is? Also, the screen on the z110 isnt switching when i put it in reverse.
There was a wire in the adapter harness that said to connect it to the HU's rear camera wire, which I did. Any input is appreciated.
The details of my system:
09 Jeep Grand Cherokee
avic-z110bt
pac C2R-CHY4
pac SWI-PS
pac SWI-CAN2
Posted Sep 15, 2009 · 21:17 UTC#2
Thanks for all the quick replies and suggestions. :mrgreen:
For anyone that has a factory mygig radio, on the white 22 pin connector, pin3 (green with orange stripe) is you video signal (+) and the pin5 (blue with white stripe) is the shield (-)
Posted Mar 13, 2010 · 07:50 UTC#3
I have seen you on the SRT8 forum. I just installed this z110 this evening and I'm very interested in getting more information on getting the factory cam to work with this unit. Any chance you could detail this a bit more?
