Speed Camera update for F900bt problems
By DengieHammer · Sep 12, 2009in General💬 2 posts👁️ 1,155 views
Posted Sep 12, 2009 · 14:30 UTC#1
Hi just wondered if anyone can help me. I put some speed camera updates on my f900bt, using the database from Pocketgpsworld for IGO sat nav. And have now got new cameras on my maps. The problem I have is initially I put the file as it came from PGPSW onto USB and tried to laod it that way, not sure if that worked, but my Uk Unit showed as having MSN direct???? I then rebotted and MSN Direct disappeared. Was not any wiser as to whether this had worked. So I then put that file within a folder called speed cams(as someone stated needed to be done in a thread) on my SD card to see if that worked, but nothing happened when I booted, so I guessed that this did not work. I then took the normal PGPSW update file and managed to find a tool on the net that converts to IGO files and used that. I put these files again on my SD card within a file called speed cameras, but again was non the wiser as to wheteher this way loaded onto the unit.
I guess what I am asking, is what one of these way, is the most likely to have been the one that loaded the files, and what type of file should i need to update speed cam for the F900bt maps
Posted Sep 26, 2009 · 10:46 UTC#2
I would like to know this too.When you update the official speed camera update onto an SD card,how do you know if the update has worked because you get no screen messages.
