NEED HELP ANY IDEAS
By jhovjcob · Sep 12, 2009in Problems/Troubleshooting💬 13 posts👁️ 1,639 views
Posted Sep 12, 2009 · 19:09 UTC#1
Need help with my f900 its been hooked up for months now and no problems and the other day was coming down the express way when it started to shut off and restart randomly. the radio will play for bout a minute sometime shut off and come back on for like ten seconds etc. and i just pulled out the unit and checked the acc and batt wires reconnected them and all anyone have an idea what could be wrong or what i should do ? thanks
Posted Sep 12, 2009 · 20:02 UTC#2
Probably the obvious but you did check the ground wire too right? Also have a look maybe the fuse feeding the line for your power or accessory is not well seated.
Posted Sep 12, 2009 · 20:09 UTC#3
you know what didnt even cross my mind ill see if that works
Posted Sep 12, 2009 · 20:52 UTC#4
and checked the ground everything was ok there still same thing and fuses are good
Posted Sep 13, 2009 · 00:50 UTC#5
Did you update it recently? Some other threads reported F900 reboot issues related to incorrect/failed update. Have a look here: viewtopic.php?f=33&t=26691&start=0&hilit=f900+reboot
If you didn't do anything software-wise with it and its doing it also when car is stationary and off without anything moving, it might be an internal power supply hardware failure.
Posted Sep 13, 2009 · 02:40 UTC#6
no didnt update it at all had the update when i purchased and doesnt do it at all when stationary
Posted Sep 14, 2009 · 17:16 UTC#8
would resetting the unit itself help?
Posted Sep 14, 2009 · 17:19 UTC#9
it's worth a try
Posted Sep 14, 2009 · 18:20 UTC#10
Try deleting a) gpsparaXXX.bin files (should be in the root of My Flash Disk). If that doesn't help, delete files from USERData.
Posted Sep 16, 2009 · 05:22 UTC#11
If this is still happening and you can't figure out the problem, you could hook up a meter to the power and ground wires and watch it carefully while driving, that's not easy to do since it happens randomly. You could invest in a logging meter such as the FieldPiece DL3 and voltage head($200), to isolate the problem external to the AVIC by driver safe monitoring(logging) of the power going into the AVIC. You MUST tap the AVIC harness wires, this can be done with "needle bed" piercing clips, close to the black connector, but make sure the clips don't short out to each other.
Posted Nov 10, 2009 · 20:20 UTC#12
i sent into pioneer the reinstalled software or something and worked fine for a couple weeks but started rebooting once again, could the speed pulse not being connected cause it to do that and be that much of a problem ?
Posted Nov 10, 2009 · 21:47 UTC#13
the VSS (speed pulse) wire not being connected would not cause an issue, I ran mine for over a month without it connected. The VSS only enhances the system mostly if the GPS signal is lost in a tunnel, between buildings etc, it is not a required hookup.
The only thing that MIGHT cause an issue with the VSS wire (or any other unused wire) is if some of the wire is exposed and it is touching bare metal or ground in the vehicle which may cause a short.
