OK so I put my Z110BT into "test mode" last night and played around a little bit. Everything looked cool, ran a couple tests, then shut it down and booted back to normal. Everything came back fine except for one small issue. When listening to an FM broadcast the RDS data does not show up properly in the NAVI mode or the "detail" mode, but is fine when looking at all the presets at once. The problem that occurs is it shows the name of the artist and station name, but then flashes 01010101, 02020202, 03030303, 1F08B5C8, then the station name and artist again....
I am thinking a hard reset my fix it but I am going to to take a look at the service manual again and make sure I didn't enter some kind of RDS testing mode that I didn't exit out of properly. I also went in to Optical Disc (DVD) test mode at one point earlier yesterday but I didn't look at the FM display after exiting that to see if it was normal or not.
Anyone else gone into test mode yet? Anyone else have the same issue after coming out of test mode?
