lineinfo_singpost
By ttorski · Sep 15, 2009in Hacks/Mods💬 5 posts👁️ 1,369 views
Posted Sep 15, 2009 · 23:21 UTC#1
On emulator my highway signs are perfect reduced size, but in AVIC nothing changes any idea why?
thats my lineinfo_signpost.ini
arrow="$lane_vsimpdir_signpost.spr"
arrow_mode=2
arrow_sel="$lane_vsimp_sel_signpost.spr"
bg="$lane_bg.spr"
bg_mode=0
div="$lane_div.spr"
div_mode=0
max_lanes=11
min_lanes=2
only_at_maneuver=2
skip_opposite=1
connectivity_mode=0
one_signpost_mode=0
signpost_bg="$signpost_template_bg.bmp"
signpost_border="$signpost_template_border.bmp"
signpost_fade="$signpost_template_fade.bmp"
signpost_bottom_padding=4
signpost_top_padding=8
signpost_left_padding=8
signpost_right_padding=8
signpost_arrow_padding=2
signpost_word_padding=5
signpost_line_padding=0
signpost_max_lines=3
max_signpost_width=230
signpost_font_size=16
signpost_pictograms="$signpost_pictograms.spr"
valid_var="bLaneinfoSignpostValid"
signpost_background_color=RGB(0,48,32)
signpost_use_road_name_if_empty=1
Picture from emulator
Posted Sep 19, 2009 · 15:47 UTC#2
Think there is more to do if you want that. I will look at it.
What F-serie do you use and what hack?????
Noce mod, where did you get this from??
Greatings Rob
Posted Sep 20, 2009 · 13:54 UTC#3
Greatings Rob
He probably got it from here: viewtopic.php?f=34&t=26901
Posted Sep 20, 2009 · 18:57 UTC#4
arrow_mode=2
bg="$lane_bg.spr"
bg_mode=0
div="$lane_div.spr"
div_mode=0
max_lanes=11
min_lanes=2
only_at_maneuver=2
skip_opposite=1
connectivity_mode=0
one_signpost_mode=0
don't base everything on the emulator, even if it looks perfect on the emulator it would show up differently on the avic, this is something i've noticed when i first started using the emulator, basically what you need to do is to check if it works on the emulator and then try it on the avic and see if it still looks the same, basically after using the emulator you still need to tweek it a bit
Posted Sep 20, 2009 · 19:25 UTC#5
Greatings Rob
F700BT, mod is base on IDTs v1 but I added bunch of stuff to it from IDTs later mods
you can download this mode from http://webpages.charter.net/torez22/
