i just got a f7010bt and i want to learn how to change like to have speed cam and other stuff plss help.
Can anybody help me to change some stuff on my f7010bt plss
start reading through the hacks thread
yes i did but for me its like i cant understand to much i just need some step to step to do that
i think it would be better to just start off using a pre-made mod (DIAFTA's, IDT's, STANIS etc) and go from there
But how I add those mod on the unit ? And what is all the test mode ?
You need to format an SD card with fat 32, put the files from the testmode.zip for 3.0 or 2.0 depending on what version of the F710BT you have and then you insert the SD card and it boots from that to the desktop where you can axxess windows explorer. You would need to have a folder on the SD card with your mods that you copy to the APL2\IGO folder. If reading through this stuff is complicated and hard to understand, you may not want to do this.
but after i add the mod on the sd card how i add them on the unit ? its like a process to go or just insert the sd card and will add on the unuit? can u send me some post were can i read more about this stuff plss thanks
