I go on vacation in a few hours, and checking that everything is correct, I find that when I zoom the screen goes all pixelated from the middle of the screen. If you zoom in very close looks good, but if I put the highest view, does not look good. If I put the zoom to maximum, then you can not see anything directly.
What happens? I've tried several data.zip, several SYS.TXT but nothing. Is there some file that you can change to paint the entire screen without pixelation?
If I change the viewing angle from above, looks very bad.
And now 3D buildings are transparent...
Thank you very much.
