European Teleatlas 06.2009 Maps
By TimboZero · Sep 18, 2009in Hacks/Mods💬 19 posts👁️ 3,383 views
Posted Sep 18, 2009 · 07:06 UTC#1
Seems that Volny is ahead of the game again.
European Teleatlas Maps now up on his site.
Versions : 2009.06 R3 (22/07/2009)
http://volny.cz/sstopar/mio_mapy_igo8_3.html
Posted Sep 18, 2009 · 08:28 UTC#3
These are 8.3 maps, do you think that this means 8.0 maps will not be updated through 2009?
Colin
Posted Sep 18, 2009 · 08:56 UTC#4
Latest 8.0 maps are also on Volnys' site. Currently only the 02.2009 are available
Posted Sep 19, 2009 · 10:43 UTC#5
not working poland map :(
only work old map 2008.10 ta (090428)
where is newest workinkg poland map ??
Posted Sep 20, 2009 · 09:29 UTC#6
Sorry Dumb question or questions
Are the 8.0 maps just a straight update for the normal 900bt maps?
and if they are, do I just put them on a SD card and load them into the unit?
Posted Sep 20, 2009 · 20:22 UTC#7
Hi there,
OK, just checked out the files and immediately wondered which ones to download...
Example:
CzechRep_NAVTEQ_2008_Q4_090310.fbl
CzechRep8.3Ceda_2009.06_090730.fbl
CzechRep8.3TA_2009.02_090602.fbl
CzechRep8.3TA_2009.06_090722.fbl
So which one should I get? I assume the *NAVTEQ_ one? But then, the version number is 2008.Q4 and not 06.2009 as this original post mentioned...
Anyone care to shed some light on this?
Thanks in advance!
Posted Sep 21, 2009 · 07:39 UTC#8
NAVTEQ maps are generally prefered in the US , Teleatlas in the EU.
I would suggest you want the CzechRep8.3TA_2009.06_090722.fbl
Posted Sep 21, 2009 · 10:48 UTC#9
You need to replace the maps in the apl2/igo/contents/maps folder with the new ones.You will also need to DL and install the updated ezrider file and install the generic license folder.There is a brilliant "How To" in an earlier thread.
Posted Sep 21, 2009 · 12:28 UTC#10
Thanks for the info, will have a search
Posted Sep 21, 2009 · 19:43 UTC#11
Did you find it? If so please could you let me know where? Searching on this forum's not the easiest... :evil: Thanks.
Posted Sep 22, 2009 · 18:56 UTC#12
In a word No! lol
I am having problems getting into testmode...I think it might be because I updated to the latest firmware yesterday :?
Posted Sep 23, 2009 · 13:57 UTC#13
Probably a silly question but here goes.Updated all the maps I needed,UK,France etc. and all are working fine.Should I update the base map and if so,why?What exactly does the base map do? :?
Posted Sep 25, 2009 · 21:45 UTC#14
how to install these maps in my pioneer f900bt?if i install these maps,clean the other maps or actualize it?
thanks for your reply
Posted Sep 25, 2009 · 22:02 UTC#15
Fine. :-) And which basemap recommended?
Posted Sep 26, 2009 · 04:56 UTC#16
Could someone tell me where the 3dc file goes in the igo8 maps?
Posted Sep 26, 2009 · 16:14 UTC#17
Installed 8.0 Tele atlas maps, along with world atlas and ezrider 3.0. Put ezrider in apl2 folder,map in maps folder and lisence in lisence folder. When i rebooted unit, it would load but i could not access navigation,but could my av. Then after 1 minute it reboot, again keep doing this. Does anyone know where i am going wrong. Oh i am on latest official uk firmware.
Posted Sep 26, 2009 · 16:52 UTC#18
use 8.3 maps.
Posted Sep 26, 2009 · 17:35 UTC#19
just to add when i put my old files back on, the unit now works again, but uk maps show as uk mre on list of maps. And when i try to navigate anywhere parts of the country dont exist.
Will try 8.3 map.
