File formats of Buildings and POIs
By TimboZero · Sep 18, 2009in Hacks/Mods💬 9 posts👁️ 1,407 views
Posted Sep 18, 2009 · 07:17 UTC#1
What's the difference between 3dl and 3dc files and do the AVICs use both ?
Thx
TZ
Posted Sep 18, 2009 · 08:35 UTC#2
I might be wrong, I read a while back that one is for building and the other landmarks. Having them both is a good thing they go into the building folder together. Normally there is one for each state, a 3DL and 3DC but they could be from different verions. So you may have a 3DC from 2008.10 maps and 3DL from 2009.6 maps and they will work fine.
Posted Sep 18, 2009 · 09:32 UTC#3
Are such files (3dl,3dc,poi,fbl & dem) named in an 'ini-file' or does the system just scan for valid files and add them ?
For example , does the UK map have to have the UnitedKingdom.fbl filename or can I call it UK0209.fbl and the AVIC will accept that (finding the map 'name' in the file header) ?
Posted Sep 18, 2009 · 09:53 UTC#4
As long as the files have the correct ending you can have the name be whatever you want. So, you could have UK2009.6map.fbl or UKmap.fbl or UnitedKingdom_map.fbl, and they would work. Same for other files as well.
Posted Sep 18, 2009 · 10:00 UTC#5
Excellent , thanks for the help.
Posted Sep 18, 2009 · 18:39 UTC#6
Can anyone describe the file layout on a storage device (USB/SD) and file format for importing POIs to the device? I know that splash screens go in a folder named "Pictures," is there a specific name for the folder where POIs will be found? I have no way to run AVIC Feeds software and am trying to import some custom points. POIFriend exports .kml files for the F- series but directs users to Feeds-SW to format them for use. I have GPSBabel+ but do not know which file format to export. Any help is appreciated.
Posted Sep 18, 2009 · 19:24 UTC#7
With GPS Babel you can avoid the whole KML import and Avic Feeds limitations. Export in iGO's UPOI format and put them in UserData\iGO\Save folder.
Posted Sep 20, 2009 · 18:51 UTC#8
Sorry to say I have not been able to make this work.
(USB:UserData\iGo\Save\points.upoi)
Device did not show any items in -->Destination Menu -->USB/SD -->from USB -->(0/0)
Posted Sep 20, 2009 · 20:10 UTC#9
Not on USB, copy them directly to AVIC's internal drive. I've never tried importing UPOIs from an external device...
