Two big problems
By kevin199 · Sep 22, 2009in General💬 7 posts👁️ 1,170 views
Posted Sep 22, 2009 · 19:28 UTC#1
I have the pioneer ft 900b!!!
In my car a corsa opc it worked for 3 month
but now i can not go into settings because the radio thinks i am still driving, but I do not drive!!!
Does somebody know a hack for that???
2. I made the hack with the ezrider and copied a map into the folder!!
Yesterday I made a new update from pioneer but know the radio do not show the map(he maybe has no gps signal)!!!
What can I do
Please help me!!!
Posted Sep 23, 2009 · 15:42 UTC#2
please help me!!!
Posted Sep 23, 2009 · 21:40 UTC#3
For 1) check your handbrake wire, it propably lost connection.
for2) Copy the hacked ezrider and license file again, you propably overwrote them with the update.
let us know if that works
Jörg
Posted Sep 26, 2009 · 11:35 UTC#4
The map works now
Thank you!!!
But I think the handbrake wire is okay!!!
It works sometimes, but sometimes not!!!
Is there any hack so that the cars always thinks I am standing?? So that i can change settings while driving???
Please help me
Posted Sep 27, 2009 · 22:05 UTC#5
There is a software hack, just use the search function.
For me it just worked to connect the handbrake wire to a 12v positive, so the Pioneer thinks the handbrake is always on.
Jörg
Posted Sep 28, 2009 · 11:22 UTC#6
@ Jörg
kannst du deinen beitrag noch einmal auf deutsch verfassen!!!
Bin aus Österreich!!!
Posted Oct 07, 2009 · 23:15 UTC#7
The update would have put a new data.zip into the APL2 folder so if you modified the data.zip previously or placed a modified one there you will need to replace it again as you did with your ezrider and maps. Make sure you remember to back up your newly updated unit too just incase you have a problem later on.
