XM has an option to let a left/right knob push change your presets instead of just moving one channel left or right. I can't find this setting in FM mode, and pushing the knob just moves the frequency .1 over...is there anyway to get the knob move the radio to the next preset?
Using knob to change FM presets?
If the Pioneer engineers would have used logic and common sense in their design, they would have programmed the knob to do track/seek with right/left push and preset up/down with up/down push. They would have also done it across all modes. Of course, that is only if they used logic and common sense, which they didn't.
I look forward to the day when "usability" actually becomes one of the design goals of Japanese hardware and software engineers.
Wow that stinks...getting sick of driving around in the FM screen just so I can skip around presets to avoid commercials...
I think it makes sense, think about it, if you've got a route planned then it's probably because you're going out of your own area, in which case your presets won't be available, so it meakes sense to search for new stations, and the easiest way to do that is to push the knob left or right.
Paul.
Ok so now my XM is going one channel at a time! I can't remember how I ad it going through the presets instead, can anyone remember the setting?
