iPhone And SlingPlayer - Will it display image on AVIC F90BT
By CGHitman14 · Sep 23, 2009in General💬 18 posts👁️ 4,415 views
Posted Sep 23, 2009 · 02:33 UTC#1
So ignoring the fact that SlingPlayer only runs on wi-fi, assuming i was in Wi-Fi range, will the Sling Player display an image to my Pioneer unit? I can listen to pandora, I can watch videos from the iPod, but I'm not sure if I'd be able to view videos from Mobile Sling Player. I know that there's not video of Pandora when that's up which would be cause for concern.
Just curious if anyone has any idea if this would work, and if not, what type of "workarounds" are there to bypass this...
Thanks.
Posted Sep 23, 2009 · 22:46 UTC#2
Anyone try this?
Posted Sep 23, 2009 · 22:56 UTC#3
I have an F500BT and I tried both the iPhone and iTouch with Slingplayer but was unable to get it to work. I thought since the XM app works that somehow the Slingplayer would but no. I have not given up though.
Posted Sep 23, 2009 · 23:06 UTC#4
I don't have Slingplayer, but other apps have worked... and also videos from websites too. (when you play a video from a website, Safari on the iPhone actually launches a Quicktime player to play the movie, which will display on the video output too)
The trick is to start a video from your iPhone first. That gets the nav unit into "video" mode. Then use your iPhone to select a video (from an app, or from a website). It will display on screen np.
Posted Sep 23, 2009 · 23:29 UTC#5
I can get You Tube and other video's but with Slingplayer I get audio only.
Posted Sep 25, 2009 · 22:34 UTC#6
Anyone figure this out?
Posted Sep 26, 2009 · 04:04 UTC#7
I wonder if you put the avic into test mode and run some sort of jailbroken app like Veency where you can control and view your iphone from the PC. Maybe then you can view the video from it.
Posted Oct 05, 2009 · 01:00 UTC#8
If you try to use youtube while plugged in, it doesn't work. If you run a video form your iphone, and then attempt to run youtube, it plays the video. I know someone mentioned something like this earlier.
Has anyone given this a shot? Run a video from their ipod and then attempt to run slingplayer?
Posted Oct 05, 2009 · 01:16 UTC#9
It will not work unless the app your trying to display supports the TV OUT extension of the iPhone. As far as I know that is not allowed from Apple on any of the App Store apps. Some of the Cydia apps do support it however.
Posted Oct 14, 2009 · 18:03 UTC#10
Well I can tell you it does work using the HTC Fuze's TV-Out and the f700bt. I will tell you a consistent connection like wi-fi is a must, because driving on the go will not hold a strong and consistent enough data signal from you phone. I tried it with my data connection and it was jumpy at best while on the move, but not too bad when sitting still. With the iphone I believe you must use slingplayer over wifi anyway, so it should display as long as you have a tv-out software downloaded. It will not work through the front aux-in, but will work through any of the rear RCA audio/video in's.
Posted Oct 14, 2009 · 20:16 UTC#11
Incorrect, it will work with the front AV input as this is the way I had my iphone connected with the Apple Composite AV cable.
Posted Jul 30, 2010 · 13:39 UTC#12
Is slingplayer still around???
this thread IS a year old... i'd think ATT would rate limit using the iphone as a broadcast device...no?? if this is still an issue.. lemme know... i may be able to hack something together.
Posted Aug 27, 2010 · 08:27 UTC#13
I've used this method to watch TV on my F900BT. I start playing a video as normal but I then enter Safari and log onto iphonetvcatcup.com and start watching one of the channels. Very hit and miss though as sometimes it plays correctly and other times it plays the video for about 3 seconds then the screen goes blank and you only get sound.
Posted Aug 27, 2010 · 08:36 UTC#14
The only time I see that is with video apps that are limited by AT&T to terminate the video signal when there is heavy traffic on AT&T's network. There may be a way AT&T can do the same through the Safari browser as well when there is heavy traffic.
Posted Aug 27, 2010 · 08:40 UTC#15
I'm in the UK so I don't think that would apply here. As I said I can get it work maybe 7 out of 10 attempts.
Posted Aug 27, 2010 · 08:49 UTC#16
What TV OUT app are you using on the phone?
Posted Aug 27, 2010 · 09:08 UTC#17
I'm not using any type of tv out app. My handset is not jailbroken at all. All I do is:
1. Start playing a video from my ipod
2. Open safari and log onto iphone.tvcatchup.com
3. select a channel and start watching it
I use a Mifi personal WiFi hotspot in my car to give me the stongest data connection. I find that 3G signals are not strong enough for smooth playback.
Posted Aug 27, 2010 · 09:11 UTC#18
That site is clearly iPhone video compatible or it would not display through the dock connector.
